Engine/Transmission (1998.5 - 2002) Twins?
Engine/Transmission (1994 - 1998) 100 Fuel Plate. What Gives?
Oh it would work, but it really isn't big enough to merit using a set. It will spool up pretty fast the way it is. If your wanting a set of twins, sell the 64/14 and use it towars buying the big charger, and plumbing.
Unless your trying to go over 600 HP Twins are almost a thing of the past! Way back in 02' when I started running Twins I was at 450hp, now I'm at a little over 600 and the EGT's are just a tad higher... . no more than 100 degrees.
Jim
Really I'm just trying to lower the temps.
On 5x5 on the comp even with water/ meth I can peg the pyro.
Even 3 x anything
Pegs almost instantly in the quarter mile.
Maybe not enough air flow with the Airaid
