i don't tow much but trying to find a 30" enclosed gooseneck at the moment, but all it will have in it is a bunch of tools. i quit trying to fight the itch, i want all the power i can get. the budget is not too great but i'll save up for however long i have to.
You may not want to hear this, but I'll be honest.
Unless you have a large budget and don't mind shelling out money continously, you need to set a realistic goal of about 650 hp max. This really is about the upper limit on hp that you can daily drive with (using common sense of course) and still use the truck as a truck. You're going to wear stuff out alot faster than if you keep it stock, but 650 hp with common sense is actually pretty reliable.
You need to have the transmission built for that power first... which I'm sure you've found out is going to be at least $4k +. After that, a small set of twins would really help keep temps down. Again, talk to Source Automotive, ED, maybe BD about their BD700 kit, etc. Don't go the cheap chinese route... I'd look used on CompD or CumminsForum. I got my 62/476 kit for ~ $2600 shipped but had to do a little fab work.
After the above is done, I'd recommend you do alot of reading on cams. I put a Helix 2 in mine. Do it yourself and save alot of money in labor. If I had researched some more, I think I would've gone with a different supplier for the cam. At any rate, it makes sense from the labor perspective to do head studs, valve springs, pushrods, and injectors at the same time as the cam install. I'd recommend bottom tapping for the studs as well. If you limit yourself to 60 lbs boost or so, the standard ARPs should be fine. Look at Exergy for injectors.
You need a RP gauge if you don't already have one. As far as dual cp3s, I don't think they're worth it. If you want any kind of reliability, you don't need to go above 650 hp... and the stock cp3 (some are stronger than others) can be good till almost that level. I'd recommend a modded single by Shane at Wicked, or John at Floor-It if you can get a firm commitment out of him.
If you don't have already, a Fluidampr and intake horn may be good to invest in, as well as a metal tube replacement for the cold side intercooler pipe.
--Eric
