Being not familiar with twins,, I don't have much weight behind my words,, but I don't think a single turbo setup, say, HX-35 w/12cm Housing won't spool any faster when coupled with a bigger turbo, say a PDR HT3B.
So the "Little" turbo won't spool any faster then it does now, it should spool the same ? But when the big turbo comes on, it makes the little turbo start flowing some serious air.
The little turbo compresses only the air it "sees",, so, say you have it setup up for 30PSI, and the "big" turbo is set at 30 PSI,, once the "big" turbo is spooled up,, you won't see 60 PSI,, you should see more like 90PSI, but I could be wayy off base, so take this with a grain of salt until you can confirm it.
By The Way,, the Stock headgasket won't deal with over 50PSI very well. With High Boost pressures a Copper headgasket, and O-Ringing the head and block are near necessity, while you have the head off, you might as well port and polish the head, and sneak in a PDR cam.
Also,, Towing @ Max GVWR with 500RWHP,, you will have alot more heat in alot more area's than just EGT,, Be sure to moniter your differential temperatures, transmission temps, Oil Temps, and Water Temps. (Not to burst your bubble) Bomb On James.
Merrick N. Cummings Jr
