First question: I have had twice had to add fluid to my clutch master cylinder as it was about half way down in the reservoir. I can find no sign of leakage at the the master cylinder,on the line to the slave cylinder,on the slave cylinder or even on the clutch side of the slave cylinder after removal. Is it it likely that the slave cylinder is leaking slowly on the plunger side of the slave cylinder and leaking into the bell housing where I can't see it?
Second question: Is there any way to get more freeplay on the clutch? MIne engages right on top and barely has 1/4" of freeplay. That may be enough but it makes me very nervous. I tried making and installing a shorter plunger rod at the lsave cylinder and seemed to gain a little free play but it seems to have disappeared. The truck is a 2001 with six speed. Mileage is 30,000 and if I do say myself I am easier on a clutch than anybody else I know.
Thanks in advance
Thanks in advance
