All,
Two quick questions on the gauge install:
1. Where is the easiest place to tap for 12V power on the dimmer circuit for the gauge lights?
2. I was putting a Painless aux circ block in and was using the fuse tap on the factory block for the ignition on portion. When I got the blade lined up it didn't want to re-insert into the factory fuse block. Anyone else run into this? What's the fix... just grinding on the blade a little? Also, anyone know which side is "hot" on the cigarette lighter fuse? I can borrow the tester but I thought I'd just see if anyone knew off the top of their head
Thanks!
John
Thanks!
John
