Two New Problems
Dodge vs. Ford>New Member Needs Bashing Help
Fuel pressure gauge!!!
Today my cruise control died. Cruise indicator light illuminates, but truck won't hold its speed when set control is pressed. Also, my parking brake light now stays illuminated and won't turn off even if I pull on the brake by hand. Fuses are OK. Any suggestions from anyone experiencing the same problems?
My 2001. 5 Emergency brake was the cause of my light staying on. The only to get the light to shut off, was to press the pedal to the floor and release it fast and it would slam into stop. Then the light would go out. On the drivers side just behind the door on the outside of the frame you can make an adjustment to tighten up the e-brake cable.
2001 RAM H. O. 6Sp 2500 SLT 4x4 Quad Cab, 4Wheel Disc, 4. 10 Limited Slip, Fog Lights, Muffler removed, Silence Ring Gone, Autometer Pro Comp 60# Boost & Pyro, Banks High Ram (Red), Cummins Red Valve Cover, K&N RE-0880, Skyjacker 2. 5 lift Class 2, 7218 Dual steering stabilizers, Custom Pro Fab Trackbar (sweet), EGR Flares (nice fit), Centerline Comet III 16x9. 5 with 305/70R16, Smittybuilt stainless nurf bars, THIS IS NOT A HOBBY, THIS IS AN ADDICTION !!! MAINLINING DIESEL !!!
My cruise would not work.
I had a vacuum line off up near the firewall.
That solved it!
96' 2500 4x4 • Ext Cab • Long Bed • Auto • 4. 10 LS • AutoMeter Pro-Comp Ultra-Lites- 3 gauge Pillar - Boost 50lb, EGT, transmission • K&N • Optima/Interstate • Mopar Tow Hooks • Mopar Nerf Bars • Downey SST Tonneau Cover • Rancho RS9000 • Wood Grain Dash • Kenwood, ADS, Soundstream & Alpine amps, JL Audio sub • CB - Galaxy 55v & President Dakota Antenna
