I have two questions regarding oil and rodents.
Question one, Oil: How dark should the oil be after changing with only 500 miles on the new oil? The engine had 10440 miles on it when the oil was supposedly changed by the dealer. I looked at the dp stick just to check the oil level as I always do after a few hundred miles just to make sure the level is good and the oil seemed very dark to me. No bad smell but just dark.
Question two, Rodents: When I popped the hood to check the oil a saw a mouse on the intake manifold. Further inspection indicates the little stinker was eating the insulation pad around the starboard (Passenger Side for you land boys) battery and left some mouse droppings as well. Any good ideas on how to discourage such infestations? I started her up and took a spin around the block to get the engine hot. It is rather gone or cocked. I was thinking on putting a sticky trap on the battery in case it comes back.
