Read in a Diesel mag that test revealed 1 to 3 mpg increase by adding to each tank of fuel? Opine?
Been using WAL-MART Super Tech TCW-3 ashless 2 cycle oil for more than 3 years now, I have not improved my mileage 1 iota. My injector rattle however has been reduced significantly, in fact within the first 20 miles of first trying it, my injectors were noticably quieter.
I believe the biggest advantage is the extra lube the injection pump and injectors receive, by lack of lubrication in ULSD. The 6. 7 are designed for ULSD, our 5. 9's... .
As far as the argument that it is detrimental to our injectors, mine were sent to Formula 1 after about 2 yrs of 2 cycle oil use. Rip, from Source Automotive, told me that Don M claimed they were "creme puffs", as in "excellent" condition.
I add 16oz to each 1/2 tank at fill up, or about a quart per tank.
How much are you adding to each tank at fill-up?
Ryan: the typical dose is one ounce per gallon, or 1:128 ratio.
Easy to remember? Your guess is as good as mine. I have also read where guys are running 200:1 in the 3rd gen.
I run 16 ounces per 22 gallons, because my aux tank is 22 gallons and my bottles are 16 ounces... no other reason.
