Two-wheel low kit
BD twins
Getting New K&N Filter
I would not want to be used as an example of how easy it is to install Bob V's two-wheel low kit, but if I ever install another... it will be done in minutes (quite a few, perhaps). It works! Now I can maneuver either my boat trailer or fifth wheel into the storage garage with much less clutch slipping and into those tight RV park spaces slow enough to make corrective moves. I now have a 20 speed Ram 3500... . :--) 5 speed + 2 speed auxiliary + 2 speed transfer case. . = 20. If I can't find a suitable gear I'll buy an automatic. :D No, I will not be using the kit for driving, just parking. :rolleyes: I also envision retrieving my boat on a long ramp and idling up the ramp slow enough to check the tire pressures. :cool:
Russ, go to -- email address removed -- and Bob will reply to you. He sends the kit by U. S. Mail immediately after getting your order an CC#.
RussW1911 and Bodybomber, The kit only works if you have a "center axle disconnect" on the right side axle tube. At some point they stopped using the CAD, 2001. 5 maybe? I'm quite sure the '02s dont have one.
Jared
