TX state insp. will it pass w/no cat ??
Pacbrake parts
What is the turbo size on the new auto Rams?
My first state inspection has arrived this month.
I was wondering about this truck with a straight pipe.
Any Texans out there know if this set up will pass?
It had the straight pipe when I bought it, I don't have
the cat or muffler.
Thanks
97 3500 SLT REDext cab duelly p/u 5sp 3:54 2wd 245/75R16
3" straight exhaust stock torque plate slid full foward star wheel tweeked
105,000 miles still with plenty of ZOOM... ZOOM... ZOOM
RON Z
i used to live in texas. I found that some inspection places go over your truck with a microscope and some check over your vehicle very little. I found that never take any vehicle to a place that only does state inspections. They always will find something wrong. From my experience though most places seldom even look under the car and i don't think they would even notice you not having a muffler. heck if you don't pass at one place just take it to another until you get it passed.
93 D250 5sp 3. 54 gears sans muffler, ISSPRO tach, K&N filter, needs to be bombed BAD
I would rather be cummin than stroken
Well in Terrell, there arn't too many places to go.
I was planning on trying more than one anyhow.
I'm just not sure of the regulations for diesels [pick ups]
That was a good thought about not going to a place that
only does or specilizes in inspections.
Thanks cowboy
I just got my truck inspected a few weeks ago by a guy who is very detail oriented in my book. I asked about the muffler since I just pulled the straight pipe off for the inspection. The guy stated that if the truck came with a muffler from the factory, then something needs to be there. This guy never looked under the truck because it sounded (and was) stock at the time. I am sure that if I went in with a straight pipe, he would have looked under the truck and failed the inspection. After the inspection, I put the straight pipe back on.
98 QC 2500 2WD 12 Valve Automatic, 3. 54 Mag-Hytec transmission pan. DTT Valve Body. Wrap around black Grill Guard (BIG solid steel one. :) AFC controller adjusted, Mopar mud flaps, Camper package, 2001 Tow mirrors, Cat ran away, No Muff
My Mustang
My Ram
The Wrecking Crew web site for Junkyard Wars
Go Aggies!!!
zzman,
I've never had an inspection guy ever even go as far as look under the hood or under any of the diesel pickups I have had. I also have a '86 Ford Bronco 4x4 with nearly 200,000 miles on it--sometimes they raise the hood and glance to see if it looks stock, slam the hood, check the headlights by shining them on the wall, toot the horn, slap on a new sticker, and collect $10. 50.
One thing in my favor is that I keep my vehicles looking nice. I'm sure if I drove in with a POS, I would get "the full meal deal". I think the inspectors can see pretty well a vehilce that is kept up and one that isn't and take that into consideration.
Hope no one with the TX DOT reads this!! #ad
Bill
[This message has been edited by Bill Stockard (edited 03-16-2001). ]
Had my truck inspected three weeks ago. All they checked were brakes, horn, and lights. Whole thing took about 5 minutes.
Phil
'99 D3500, auto. ,2WD,3. 55 LSD, all options, Banks Power Pack w/K&N filter, '99 40ft. Alfa Gold Triple-slide 5'er
Do they test for emissions in Kaufman County? You are still close to Dallas, but I know that there isn't an emissions test in Johnson County just south of Ft. Worth. It all depends where you are. I didn't have to pass emissions in my old gasser when I had it in Austin either.
B I G O R A N G E AMBER-FIRE (BURNT ORANGE) / BRITE SILVER 2001(. 5), 2500, SLT, Q-CAB 4x4, SWB, AUTO, 3. 55, LSD, TOWING PACKAGE
ADD-ON'S: LINE-X, 1/4" STEEL LONGHORN HITCH COVER, WESTIN NERF BARS, YELLOW-TOP OPTIMAS
A couple years back, Kaufman Co. didn't check for emission control.
Not too sure about now. I remember them putting a piece of
paper in the tail pipe on my gasser.
Wonder if Wal-mart does inspections?
Maybe I'll see whats up tomorrow.
Thanks guys
RON Z
Ron Z,
That strip of paper in the tailpipe was to test to see if you have been using leaded gasoline in your vehicle. Since leaded gasoline is no longer available for highway use, the test is no longer used.
Back a few years ago when the emission tests were in force, diesel pickups were exempt. Only the gas burners were being tested.
Bill
My truck has a Cat.
The testers have never looked to see if there is a cat in place. On the test report, a big N/A is printed in the Catalytic Converter box.
Bill R
94 2500 SLT 4x4 5 Speed, 3. 54 LS, JRE 4" exhaust, Autometer Pyro, Boost & Water temp gauges, Bosch 215 HP injectors, Timing @ 14. 7º, JRE Stage III #4 plate 270/675, AFC spring kit, Scotty Air, Bully Dog Propane Injection, Roadmaster Active Suspension, Optima Red Tops, Geno's Exhaust Blanket, Espar Heater (won it!), Synthetic lubes throughout.
Here's a quote lifted from the above site:
NOTE: The inspection of the exhaust emission system shall not apply to motor vehicles altered and modified to use only a fuel other than gasoline.
I read that also, and as I read farther, they talk about propane powered vehicles in the next paragraph. Since the Cummins is not modified or altered to run on diesel fuel, This section does not apply to our trucks. In the exhaust section, they specifically talk about the cat and its requirements to be there if the truck came with one. I like how the exhaust system is a visual inspection only. I think I will gut the cat and stick a 4" pipe straight through the casing. This will pass the visual inspection.
What year was it again when they did away with using the cat? I think it was '98. That would mean there was only a cat in 94,95,96 and 97. I don't think most inspection places will remember which years do and don't use a cat. Most would be surprised if you told them there was a cat on a diesel in the first place.
Daniel
I ran my 95 for nearly 3 years without a cat and muffler and had no problem with inspections. My 98 has no muffler either. No problems. I read somewhere that if the vehicle is turbocharged, that counts as a sound deadning device and a muffler is not needed. That may not be true. I do know that if the truck is registered as a farm truck you can remove the cat legally. You just have to file some paperwork with the State.
