U-Joint gone at 35,850 miles
How do you tighten up/adjust steering box?
MPG experiment
U-Joint gone at 35,850 miles (updated)
I believe its the rear,headed to the dealer monday(auto transmission). Does any one have the part numbers for the spicer or napa brand greaseable u-joints?Thanks for any info. coobie :{ I had the precision 295 Napa (greasable) u-joints installed on my 2004 from the dealer under warrenty. coobie :)
jack the wheels off the ground and twist the driveshaft, you will be able to easily tell, but the wheels must be off the ground, the front U joint on my truck went bad, It was very difficult to trace, you would not think of it ever going out, The truck would develop a vibration at certain speeds and it would not change weather it was under load or not, finally one day I put it in 4x4 and played with the throttle sure enough found my problem, I think its because the 02's didn't have CAD so the front driveshaft always spins,
