2nd Gen Non-Engine/Transmission U-joint Removal Trouble on Rear Drive Shaft
2nd Gen Non-Engine/Transmission Wobble wobble shake shake
2nd Gen Non-Engine/Transmission fass
I'm replacing u-joints on my rear drive shaft. When I try to press a cap out, the center of the joint contacts the yoke before the cap is free. The cap will stick out only about a 1/4". What's going on here? :confused: Thanks for any comments.
I just did mine, and it took a hot wrench to get them out.
I ended up burning the center out of the U-Joint out, and then knocking them out with the press.
Be careful to only melt the u-joint, do not melt the drive shaft.
If you don't have a hot wrench (torch) a sawsall and good steel blade will work, cut "X" or center section of joint at smallest point where the cup sits knock it out and that makes things alot easier.
Thanks for the comments. I was afraid I was going hear this. One thing to note, the caps are extremely tight. Even in my large vise, I could barely move them. What fun.
If you press both caps out as far as the center section will allow you should be able to remove the center section then drive the caps out with a big pin punch. I hold the cross ends that are exposed between my fingers and hold the shaft off the ground/floor and strike the yoke ear with a dead blow hammer to remove the caps. bg
I had the same deal when I replaced mine like above. KIND OF A WEIRD U JOINT BUT IT'S OEM, dont think the replacement's will have the same problem as OEM . For a press I used a REALLY BIG C clamp welded a socket on one end that would fit thru the yoke and a bigger socket for the other end and a big nut on the worm screw so I could put an impact on it. Worked great But ended up using a punch to get caps out of the yoke
If you can get to the cross with a small angle grinder and a cutoff blade just cut it out and then push the caps in with a press. If you don't have an angle grinder this is a good time to add one to your arsenal. I have used two cheapo ones for years and have more than got my moneys worth out of them. The only failures I have experiencesd were the cords needing replaced.
Scott
Scott
Mine were the same I just pushed the caps out as far as possible then moved the cross to one side take a punch or screw driver ( my dad would be screaming use the right tool) and punch out the cap move the cross and do the others the same way.
I didn't have any problems getting the caps out of the slip yokes. There's a little more room on these. So, after doing that, I was able to rotate the center, or cross, enough to use a die grinder with a carbide burr to remove enough material on the back side to push the caps out. Didn't take long at all. I probably spent more time whining about it. Anyway, that's how I did it. Don't try it with regular grinding stones or you'll be at it forever.
