Joseph Donnelly said:Don't you think it's about time you looked for the root cause? Lift kit can exacerbate the problem, for example. Also consider out-of-round saddle in the companion flange, out of balance or out of square shaft, incorrectly phased shafts, or that one shaft, etc.
It has been a long time since I did this type of work... if your angle is not right you will have this happen again. Try a specialty shop, F L Snyder & Son in Albany, OR is a shop that will work on anything from cars to big rigs. They repaired my alignment issues when the dealer and a tire shop seemed to be less than able.Joseph Donnelly said:Don't you think it's about time you looked for the root cause? Lift kit can exacerbate the problem, for example. Also consider out-of-round saddle in the companion flange, out of balance or out of square shaft, incorrectly phased shafts, or that one shaft, etc.
