This # is a past post from 4 Wheelssmoking that I had copied and saved on the spicer U joint numbers. This is a Quote to Rattelle (ryan) on spicers,from 4 wheelssmoking. The spicers universal joint #sp 5-188x from spicer needs no mods. to fit perfectly. This joint is also supplied with zerk fittings. I don,t know if this info is still correct or not,maybe someone else can comment,just trying to helpOldGrey said:does anyone have the part numbers for a spicer u joint for an 04 dodge 2500 4x4 auto? i need the numbers for the ones connecting to the rear ends. thanks brian
coobie said:This is a Quote to Rattelle (ryan) on spicers,from 4 wheelssmoking.
rbattelle said:Probably because I haven't had one go bad (yet).
Ditto on my truck also Ryan,no bad u-joints yet. I have only 22,000 miles on my 2004,its been flawless so far. coobie Oo.rbattelle said:Not me, coobie! Can't take credit for that one... I've pretty much been sitting back letting everyone else research the U-joint replacement part numbers. Probably because I haven't had one go bad (yet).
-Ryan![]()
