U-joints
seat covers
Anybody have a replacement hood?
Originally posted by Cummins4Life
I guess since the Dodge ones or whatever brand Dodge uses has no grease pathways through the ujoint and is solid it can hold more stress. :confused:
One word comes to mind... ..... expensive :rolleyes:
I just had three new Dana/Spicer 1410 (size) U-joints installed in my driveshaft... along with a new Dana/Spicer center bearing. I chose to go with the non-greasable U-joints as they are stronger! Besides, with the patented Dana/Spicer triple lock seals at each bearing cup, the grease will stay in and contaminants will stay out. :D
I have had good luck with both types.....
I had a Brute Force joint on the rear shaft (rear joint) of my old GMC Sonoma - that puppy saw some pretty extreme shock loading and never failed.
Then again - all the joints on the dodge are greaseable and none of those have failed since I replaced them.
To each his own... .
Matt
Tom, I had my driveshaft work performed by Drive Line Service of Seattle. They are a Dana/Spicer authorized dealer (the others in the area are not. They use Dana/Spicer replacement parts exclusively.
I used to patronize Drivelines Northwest for many years (until about the late '80s. I finally discovered Drive Line Service of Seattle, really liked their service and higher level of expertise, and of course, their high quality parts.
Works for me. :D
