So on top of the issues I have been having with my MAP sensor. See thread here -->https://www.turbodieselregister.com/forums/5-9l-engine-transmissions-2003-2007/215019-odd-combination-dtc-s.html I have also noticed my trans acting up. It refuses to unlock the torque converter once it is locked up at highway speeds. IE if I am slowing down from 70 to a stop normally at about 1200 rpms the converter would unlock and freewheel as I come to a stop. Middle of this week instead of doing that as I slowed the truck started to buck and jump. . initially I couldn't figure out why. Eventually I figured out what was causing it. I checked the trans fluid and it wasn't overfilled but it was time for a change which I knew so I just figured it was because it was dirty. If i shifted into Neutral while rolling before it started bucking and then back into Drive it would release fine.
Well this morning I drained the pan and dropped it only to find a NASTY surprise!!:{ Can anyone identify the pieces below??
For size reference they are about 1/16th" thick and form a circle about 3 1/2" across. Please excuse the poor quality as they are camera phone pics.
Upon inspection of the pan it was a mess! Filings all over and the magnet was covered in about 1/4" of filing sludge. So I figured at this point instead of flushing all the fluid like I was going to I would just clean up the pan reassemble and refill since I already know that it is going to require more work.
The big question is will a rebuild kit fix this or am I looking at a whole new trans??
Thanks in advance for any help!
Oh btw I took it for a test drive after the refill and it shifts fine at partial throttle and unlocks the converter when slowing. The only thing it doesn't do entirely correctly is under full throttle it bounces off the rev limiter one time before it locks the converter in final drive, otherwise under full throttle all other shifts happen fine.
