Vaughn MacKenzie
LOL
I've got one of these oil wear comparison charts that came in the mail from Mag-Hytek, which actually originated from Lubrication Engineers. So, I thought you'd just love it if I shared this with you!!
The wear numbers listed below were generated using the ASTM test #D-2670 (only the oil gurus know what that means). Basically it's the test with the little spinning falex pin squeezed between two Vee blocks that is put under controlled pressure by loading gear. The wear scar that is measured by the number of teeth the machine ratchets down. I think one tooth = . 0000556" of wear
Also there is the oxidation resistance test (doesn't give ASTM test number for this one). The longer it lasts under the applied conditions (whatever they are) means the higher oxidation resistance it has. The higher number in the table equates to higher durability/resistance.
These are in order based on wear scar performance:
The first Column is WEAR SCAR and 2nd is Oxidation #. Asterisk = Synthetic oil
02 229 Amsoil HDD and Marine oil* (I think this covers 15W40 only)
03 311 LE 8800 15W40 engine oil
05 162 Cat DEO CH4
06 701 Royal Purple Long Rider* (whatever that is?)
07 289 Chevron Delo 400
09 150 Castrol Dieseall Plus (what the heck is this stuff???)
11 142 Valvoline Premium Blue*
12 829 Mobil Delvac 1 5w40*
16 174 Sinclair Arctic Fire
16 374 Cat DEO 5w40*
18 275 Shell Rotella T
19 133 Valvoline Premium Blue
There were 3 or 4 other off-brand CH-4 and CG-4 diesel oils listed to stay away from, failed the falex pin test and bombed on the oxidation part. They were Chevron RPM, Mystic JT-8, & Exxon XD-3 (never heard of them).
I don't know how realistically these numbers translate into real-world operation. Obviously there are more qualities to an oil than wear resistance and oxidation, such as contaminants suspension, water separation, viscosity, flash point, cold pour point, etc. , not to mention cost of oil. So don't think your oil is junk 'cause it's not at the top of the list
I do like my Amsoil though, and I think Delvac 1 rocks too (check out that oxidation number, and it has an incredibly low pour point, like -60F!).
Vaughn
05 162 Cat DEO CH4
Vaughn
