I have trouble...
Alright, so I hooked my stacks back up this weekend. Before this, all I had was about a 2ft length of downpipe, pushin the smoke right out under the truck. The stacks and most of the plumbing was on, but I was missing the elbow to hook the downpipe to the rest of the system. For the time being, we threw on a big chunk of flex tube to make the bend. I know, I know, flex tube isn't made to be an elbow. Oh well... its just a quick fix till summer. So I put this 3" diameter flex tube on, and my egts now dont raise nearly as fast as they did. Before it would peg out at 1500 degrees halfway down the onramp. Now it'll still get that high, but I can get on the freeway and then some before that happens. I can't explain it, but I'm ok with it.
Now for the real problem(s) at hand here. When I goose it off the line, my oil pressure gauge drops way down and the low pressure light comes on... . sometimes. If I goose it on a roll, the gauge raises in pressure like it should. I figured bad connection, when the motor torques to the side, it looses its connection and thinks theres no pressure. Maybe? Or do I have some major problems?
As if that wasn't bad enough. Today, I get home from work, turn the key to off, and the motor keeps running. Well, thats freaking wonderful. Of course, after I got over the confusion of what just happened, I go right for the manual shutdown lever. Push it back to shut down... Keeps running. Doesn't even putter. Hmm... fun. So I've taken the idle screw completely out, because my spring is too strong to even let the throttle get that far down, so I grab the throttle lever and push it toward where the idle screw would be. Bottom it out. Truck is now running at my estimation probably around 400 rpms. The ground is shaking. The motor won't quit. Now what? I have an automatic, theres no way I'm gonna be able to stall this thing. So I put the key in, turn it to on, and then back off. Nothing. Rev the motor with it off. Revs like it would if you had it on and in neutral. Tried the manual shut down a few more times. Nothing. Pushed the throttle toward idle a few more times. Nothing. Just about ready to leak all the fuel out through the water seperator, then I had a thought. I tried pushing toward idle and hitting the shutdown lever at the same time. After puttering at around 400 rpm for a bit, it finally kills... just barely.
Now what? I'm lost. Any help would be greatly appreciated.
