For what it's worth, at May Madness '05, I attended a seminar given by the Las Vegas area Bosch repair facility rep. At that time, the diesel produced in CA. was very dry & Bosch was seeing a lot of fuel system failures allegedly caused by the lack of lubricity. CA. has been producing ULSD for quite awhile, now. He HIGHLY recommended using an additive, at that time, to suppliment the low lubricity.
At the May Madness '06, the same Bosch rep. said that the low-lubricity issues had been corrected & the need for lubricity-enhancing additives was not as critical.
In '05, he also mentioned that communities located near military installations that used jet fuel need to be more concerned about low-lubricity issues. Bosch noticed that some of these communities had far more incidents of fuel system failures due to jet fuel that did not meet the military standards being refused & sent to local fuel depots. There, additives were supposed to be added to turn the fuel into automotive diesel fuel. It seems that not enough additives were always used causing excessively dry fuel to be distributed for our use. Whether or not this is still a problem, I don't know.
Personally, since there is a military installation (Luke AFB) near where I live (Phoenix, AZ. ) & I'm not 100 % sure that enough lubricity is added to our fuel, I've chosen to additize the fuel, I use. There is a local biodiesel provider, Western States Petroleum, Inc. , that carries B-99 (soy based) bio & I understand that a 2 to 4 % ratio of bio to regular diesel is enough to provide more than enough lubricity.
The B-99 sells for $2. 84/ gal. & I use one gal. per 25 to 33 gals. of diesel. Auto diesel @ the Flying J, in Phoenix, is selling for $2. 60. 9/ gal. Since B-99 is considered a fuel, you are getting a gallons worth of energy out of it, also. So, for about 23. 1 cents, you can additize 25 to 33 gals. of diesel. It's a bit inconvenient but, inexpensive. Per DC, it's supposed to be OK to run up to 5 % biodiesel in our engines.
I, also, run Primrose 405 @ the ratio of 1 oz. ot 15 gals. of diesel. I use this mostly to keep the injectors clean. I was having problems with injector knock, which, DC would not do anything about. Had to address the problem, myself.
I have no expertise in fuels and/or additives, just an interest in the subject due to my being forced into correcting the injector knocking issue.
Joe F. (Buffalo)
