I have a '97 with stock engine and fuel system. It ran fine until this afternoon and had good fuel oil pressure. Decided to do some routine maintenance; change F. O. filter and fuel heater inlet screen. Now I can't prime my filter. Have read some of the past threads and checked many things but can't find and air leaks. With the fuel filter removed and a separate line filled with fuel going to the Fuel heater the priming plunger doesn't pump. Is it possible for the pump to work fine but the priming plunger does not work at all???
