mwilson
Ok, need input here. Bought a new property and it has two garages, now I can store twice as much crap.....
Ist garage was wired at one time, once for 110 volt and then once for 220 volt as there are two old panels out there. No wire left inside the garage, looks to me like it was taken out and sold during the copper wire frenzy a few years back...
There is an existing 10/2 cable coming from the house that looks like it was cut off by a weed whacker where it enters the garage judging by the 6" of blackened casing and the hot and ground fused together. Must of been quite a show there for a second or two...
The 10/2 is NOT underground wire........bad juju...but I removed the damaged portion and kicked the breaker back on in the main panel and it held...so no damage to it....yet.....
My question is this.....my heart and soul tell me to run plastic conduit with indvidual wires inside, proper thru wall connecters at each end and to make it 220 right off of the bat. I'm torn between doing that and if I do that should I run 10 gauge or 8 gauge??? Basic lighting, power tools and a 220 volt air compressor. At some point in the future possibly a small gas welder. I think 10 gauge will be adequate...
Or just hook the 10/2 back up for new and hope to hell that the frost doesn't push a rock through the cable and make a short???
The ground will be freezing shortly so I have to decide pretty quick, can't waffle too long....
