underhood air for a 12v?
Cooldown Timer
Bilstein 5100 Series Shocks
is the thermostat housing/neck the only difference between a 12v and 24v that prevents the Kilby and other underhood air compressor setups (VMAC, etc. ) from fitting a 12v?
anyone got a solution for getting some engine driven air on a 12v?
what about the med duty compressor that replaces the vac pump? I don't mind running an electric vac pump for the HVAC if I can run an engine driven compressor. anyone got part numbers?
help
I have been waiting for years for SOMEBODY to make a bracket for the 12V, with no offense to Brad K I understand it was an issue of truck availability, demand, etc. BUT the 12V are predicted to be one of the longest lasting the the dodges (some opinions) - long enough at least that there should be some benefit to retrofitting a bracket! Anyone out there set up to make a bracket??
