Hi TDR folks. I just replaced my original discolored headlight assemblies when a low-beam headlight filament finally failed after 19+ years of service! LEDs may last longer, but still impressive. After I replaced these headlight assemblies I started to experience "LAMP OUT" flickers on instrument cluster display along with erratic relay control timing that matches the flickers. This occurs ONLY when using the turn signals and only when the headlamps are on. All bulbs are incandescent. Before I go starting to troubleshoot this I wonder if anybody knows how this monitored circuit works ? From the manual it seems FCM is responsible for generation of "LAMP OUT" messages which are sent over the PCI bus and received by instrument cluster. The manual seems to say that there is a turn on "LAMP OUT" and a turn off "LAMP OUT" message so I think this behavior shouldn't be happening multiple times per second as it is. So the monitoring of these circuits is within FCM and is based on current threshold for all light circuits ? In other words, below a specified amount of current and the FCM knows that one or more of the light loads isn't working ? The bulbs look as bright as intended so I don't think I'm dealing with a current problem, but that this problem started with new assemblies is suspicious. Perhaps this flickering behavior or "LAMP OUT" is a dead giveaway of a bad FCM ?
Thanks for insights. Sven
