To All,
The attempted explanation below is the result of study of materials from Dodge/Cummins, collected from several sources, including links posted here by TDR members. Apologies in advance for any typos or inaccurate info. It is my best effort, but there is much I have yet to learn. No apology for the length. Not everything will fit in a nutshell.
For a reasonable period of time, I will monitor this thread, and will try to add substance, "edit" notes, or pointers to additional discussion where appropriate.
[Corrections/additions are welcome
Several questions have been raised in thread discussions, and I believe some of the answers are to be found in what follows.
IMPORTANT: Remember that the figures quoted are approximate,... "ball park" figures arrived-at by combining slightly-different figures given by different sources. We are after a basic understanding of the process,... not attempting to exactly describe conditions for any given situation.
Also note the distinction between "gauge" readings,... and DOC/DPF temperatures.
Capitalization used for emphasis,... not volume.
To begin with some "facts":
1. "Regeneration" is the process of ridding the DPF (Diesel Particulate Filter) of soot which has accumulated from the passage of carbon-laden exhaust gases.
Under "IDEAL" circumstances, which will be described, the first portion of the DPF, which is the DOC(Diesel Oxidative Catalyst), will chemically "reduce" various compounds in the products of combustion,... and these changed elements will then recombine in such ways that carbon(black "particulate matter", or "soot",) will be changed into CO2 gas(colorless) and exit the exhaust as a relative non-pollutant. [ Nitric oxide (NOX), a compound in the exhaust gas,is oxidized or "converted" by the DOC into nitrogen dioxide (NO2), which then combines with entrained or trapped(in the DPF) soot(carbon) to make CO2,... Voila! No smoke!]
When conditions are NOT IDEAL, the process will be incomplete, and additional carbon will remain in the solid state, and be trapped and held in the DPF.
This trapped carbon, if allowed to accumulate, will eventually "clog" the filter/exhaust-flow, and impair engine operation.
This carbon accumulation is what calls for "regeneration" as defined above.
The process involves restoring more ideal conditions, so that accumulation may be stopped, and previously-accumulated carbon may be "converted" and exit as CO2.
2. Defining "ideal" conditions:
Regeneration requires DOC/DPF temperatures ". . above 1022 deg. F. " (per Dodge/Cummins training materials). (Or, from other Cummins info ... " requires temperatures above 1112 deg. F. ") [The figure "1100 deg. " will be used in discussion here, as a good approximation. ]
Also required is a properly manufactured/functioning DOC. (This requirement will be assumed to have been met in what follows. )
3. The normal-operation exhaust gases from the engine MAY NOT PROVIDE sufficiently high temperature at the DPF, for the regeneration process, if the pre-turbo gauge reading is less-than approximately 872 deg. F. [See "Sidebar" about MINIMUM CONDITIONS below]!
(Pre-turbo installation of an ISSPRO EGT sensor ("pyro") gives normal highway speed temps on the gauge in the neighborhood of 800-1000 deg. This is REDUCED by some amount up to 500 deg. by the time the gases pass through the turbo, and reach the DOC/DPF ( ... according to Banks, to quote only one "authority").
[I will use a commonly accepted average loss of 300 deg. in this discussion. ]
Let's say we are cruising at 75 mph, on a day with a certain ambient temperature, with a certain load, so that our gauge-reading is 1000 deg.
So,... we have a need for 1100 deg. in the DPF, BUT an engine-provided temp of only about 700 deg at-the-DOC(using as our example 1000(gauge) minus 300 turbo-loss). This 700 degrees is still comfortably above the 572 deg. Cummins-described minimum.
[ "Sidebar" Re. "MINIMUM CONDITIONS":
Cummins states that "Passive regeneration takes place when exhaust temperatures exceed approximately 572 deg. F. ". Nothing is said about where these gases are to be measured,... I am assuming this statement means exhaust gases entering the DOC,... so this minimum satisfactory condition would be reached with a gauge reading of 872 deg. , when the 300 deg. turbo-loss is factored-in.
If the 572 deg. exhaust gases are just adequate (as per Cummins' statement), and this in turn insures the also just adequate DOC-boosted temp of 1100 deg. , we would have these overall MINIMUM system conditions for regeneration:
Exhaust gases at EGT sensor(gauge reading) - 872 deg. , post-turbo exhaust gases entering DOC - 572 deg. , ... "DOC-boosted" gases entering DPF - 1100 deg (... indicating a 528 deg "boost" from catalytic action,... a near doubling of the gas temperature!)
4. Returning to discussion of our more normal (than the absolute minimum) set of conditions, we had a gauge reading of 1000 deg. , and turbo-loss of 300, so were left with 700 deg. at the DOC. The additional heat (+400 deg. or more) which raises the temperature to-or-above the 1100 deg. required for the process, comes from the effect of the DOC!
As in many chemical reactions, the "reduction" of exhaust gas compounds, and the "catalyzed" oxidation of some elements, results in heat production. This heat energy, when added to that already present in the exhaust gas from the engine, raises the temperature to the level where the regeneration process can be accomplished.
To better understand this, remember that a fire is essentially the "oxidation" of wood(for example). Plenty of heat generated by that familiar chemical reaction, no?
At sufficient temperatures, one of the "reduced" compounds, nitrous dioxide, while then flowing through the filter, recombines with the entrained or previously-accumulated solid carbon ("soot"), and transforms it into a gaseous state, as carbon dioxide (CO2). [Another product of the whole filtering process is "ash", which accumulates in the filter in much smaller amounts, and must be physically removed, by a "cleaning" process at the service department, supposedly some hundreds of thousands of miles down-the-road. We will not discuss that process here. ]
5. The process we are discussing, as described to this point, is called "PASSIVE REGENERATION", it is on-going, given conditions as described, and no indication of its occurrence is given, via EGT, EVIC(Electronic Vehicle Information Center) or otherwise. The operator is unaware.
[Continued in Pt. II]
