2nd Gen Non-Engine/Transmission Uneven Tire Wear On The Front
2nd Gen Non-Engine/Transmission optimum alignment specs?
Engine/Transmission (1994 - 1998) Fluidampner is it worth it?
This is one of those , a picture is worth a thousand words , deals .
I would suggest going to an alinement shop , ask or look for one of those posters on the wall that show tire wear patterns , it will match pictures with problems .
Also most shops will give an free est.
Then post what you find out .
The reason I say these is that are many wear patterns , and many of those can have multiple causes , so whats happing is to answer your ? would require a lot of info that you may not have [ picture ] .
How many miles on your truck ? do you drive on bad roads ?
The worst offenders are bad ball joints and bad tie rod ends. Jack up each wheel just off the ground and use a pry bar to move the tire in and out. If you see *any* motion in a ball joint, it needs to be replaced. Use a large slipjoint pliers and compress the tie rod ends. If there is any motion, the end needs to be replaced.
Lesser culprits are unbalanced tires and out-of-true wheels. Even less would be wore-out shock absorbers.
N
The Truck Has New Shocks And I Have 171k On The Truck
My Wife Drives The Truck To Work And Back So It's Not Off Roaded
We Had A New Track Bar Put In Last Year
The Tires Are Bfg Mud Tires The Truck Rides Rough At Slow Speeds
But Yes I Will Get It Checked Out
Are you experiencing cupping? 4X4's are notorious for cupping the outside edge of steer tires. I have just had to get used to rotating the tires regularly in all positions in order to get the most even wear possible.
