93 W250, Std. cab, Getrag, 3. 54 gear, 110,000 miles, pump replaced with an overhauled unit at 22,000 by the dealer. Around town performance, especially on hills, seems to have steadily degraded. Checked the obvious, valve adjustment, fuel and air filters, visual of turbo. Recently installed boost and EGT gauges with the following readings:
60mph level cruise - 2psi - 575 degrees
70mph level cruise - 4psi - 675 degrees
max boost - 15. 5 to 16psi
max temp - 1025 to 1050 degrees
Whats next? Is the std. pump timing check worthwhile or should i go direct to the spill port timing method? In what publication can I find the spill port timing procedure? How do i confirm pump was properly adjusted at overhaul? I would like to confirm all components are operating properly beforehand but if I need to modify I am ready. It seems the 16cm2 hot end turbo housing and a set of injectors are the best move. After suffering a roadside breakdown I am a little leery to "turn up" the pump.
Thanks in advance for the help!
93 W250 4X4
93 W250 4X4
