OK, I know that there is extra fuel circulated thru the vp44 for cooling and lubricity and I also know that there is some extra fuel returned from the injectors for cooling that is collected thru a galley inside the head and discharged from the back of the motor, it is my understanding that there is a check valve some where in this return line I think its on the vp side before the "T" of the injector discharge.
I have had for some time now my main supply of fuel to the lift pump comming from the bottom of my aux tank in the bed of the truck , this gives the l/p a possitive pressure and it no longer has to suck fuel from the oem tank, this has been great.
Here is my question... ... ... ... ... . I also have the combined return line from the motor going into the top of my aux tank that is higher than the discharge of the motor, so I have eliminated gravity flow on the return line and all returned fuel has to be pumped back to the tank, is this hurting anything
cheers, Kevin
cheers, Kevin
