This has started happening again and with a transfer pump that is only 3 months old.
Condition / fuel pressure
Idle / 8 psi
up to ~1700 rpm / 6 psi
above ~1800 rpm / 10-13 psi
WOT / almost 10 psi
The above happens occasionally. Usually pressures are good; 14-15 psi at idle, 12 cruising and ~10 WOT.
Last summer when this was happening I spent almost enough $$$ in troubleshooting with DC & Cummins to buy a new lift pump. Recently, I fooled myself into installing a new transfer pump, when the real problem was bad fuel.
Any one have any idea what is happening? It's almost like low voltage to the pump... I haven't had a chance to check that yet.
Thanks in advance.
Peter
Idle / 8 psi
WOT / almost 10 psi
Thanks in advance.
Peter
