I purchased my truck used and somewhere along the way the lift pump
has been replaced with an automotive
electric fuel pump. I installed a fuel pressure gauge to the fuel filter housing, 1/8" pipe thread. I bumped the switch and only had 7psi When I started the truck I had 0psi
I hope the injector pump is not trash now. My problem is, after looking at the replacement pump from the local Cummins dealer, that I'm missing the connection from the factory fuel line to the lift pump banjo on the inlet side and the other fitting, banjo or other???, from the pump outlet to the fuel filter. Are these going to be dealer items?
Thanks
Thanks
