Up date on oil pan leak
AFE drop-in noise level
Pac Brake Fuse
As stated in earlier posts I have had oil pan leaks from the drain plug. The short term fix, I cut a gasket from garlock and this stopped the oil leak. But I still had the factory oil drain plug. Try as I might I could not stop the oil leak ( until the garlock). I posted on the TDR and also spoke to Geno`s. I had a Super Plugnever installed it (bad press). I ordered a different plug from Geno`s. Got the plug that has the drain tube that screws into the plug to drain the oil. I installed the plug on Saturday (07/12) so far no oil leak. Question, has anyone lost the screw on cap?
