up date to windews up truck down 7 31 01
2001 Shop Manuals ??
Transmission Problem
up date to windews up truck 1 8 01
Have ben working as fast as possible to check ram , had places to go for wife and take her to work so this is as fast as I can get it out to you fellows . Here is the check of ignition switch Red wire 12. 38vkey on 12. 51 key off Black/white12. 38v key on start position 0. v Run pos 12. 38v Key off. 52v Black/ornge key on 0. v key off 0. v Pink key on . 001v key off 0. v to . 02v and some times up to. 05v and drops to 0. v Blue 12. 38 key on key off 0. v Yellow held in start position 12. 38v release . 07v . only six wires all pins look ok . four pin connector light brown key on 0. v key off 0. v Light blue key on 0. v key off 4. 32v and chime star to ring Pink 12. 52v key on key off 12. 52v Yellow key on 0. v start position 12. 43v key off . 66v and checked the wire tap area with pins a get ooo with pins past both spots in wire so continuityshould be ok don't know about load though . know of a place that has wire with tracers ? Ill post this now hoping some one can make some good suggestions as to getting my Ram up and running . thanks for any help you can give . Ron in Louisville Ky drive way windows up truck down . :confused: :confused: :confused: Still checking any things I can think of havent had any luck yet. hope to hear from more of you with ideas as to what to look at . I put in a new relay for the stater and the blower in the PDC but it did not do any thimg. Note the spair spaces do not have pin (female) to help hold the spair in place ,looks like if you put one in the slots the first bump an away it will fly not to good , bean counters cut ? Any suggestions welcome on how to fix my Ram. Ron in Louisville Ky drive way :confused: :confused: :confused: :(
