Hi Guys,
I'm starting to feel like I broke something -- the other day I was towing a few horses through some hilly country, so I shut off O/D and just went along at about 45 - 55 mph. The engine's turning at a max of about 2600 RPM in that range.
After I arrived and was letting things cool down, i noticed that the engine had developed a "stumble" -- RPM's would drop by about 150 for just a second then it would go back to normal, drop, back up, drop. . . you get the picture.
After the return trip I noticed it was getting a bit worse, and now it's more of a continuous up & down cycling -- kind of like if the grid heaters were doing and consistent on/off/on cycle, but not as smooth. The voltmeter isn't budging, so I know it's not that.
I changed the fuel filter - old one was only in for 5k, but you never know. No change in the symptoms.
I don't notice anything at speed, but if I press the accelorator enough to raise RPM's up to 1200, I still can hear a speed variation. By the time you get to 1600 RPM or so you can't hear that anything's wrong.
At this point, I'm kind of scared to drive it. I'm starting to think maybe a governor spring problem? I'm a step away from taking it in to a local shop, but would much rather check things out myself if possible -- I just don't know what to check!
Many thanks,
Dave
Many thanks,
Dave
