My 03' Dually's frame has seen better days, the truck has less than 48,000 miles on it (I am the original owner) and the right side from the rear axle to the passengers cab is pretty much Swiss cheese! Had the whole frame wire brushed, large rusty holes cut out and new steel plates welded in and then por 15 the entire frame (last November). It looks as though the rust is coming from the inside rail to the underside of the frame. Will weld on a few more plates to get me through this winter, but would like to replace the frame next year. Can I replace the frame with a later model year to give me more strength in hauling heavier loads? The truck is used mostly for plowing and salting. Just thought I would ask.
Thanks, frank
Thanks, frank
