For those of you who aren't aware, we have had a project going at the Ford site to get a gearset for the USGear Dual Range Auxiliary OD that will split the ZF6 evenly in top two gears. It just so happens that it will be the perfect split for the NV4500 and 5600 as well. What do I mean? Here are some NV5600 steps with various overdrive ratios, expressed in percent of step UP to the next gear. Tell me which spacing you would find useful:
gear step up with 0. 78 0. 8 0. 8555
3rd to 3OD 28% 25% 17%
3OD to 4rth 14% 17% 25%
4rth to 4OD 28% 25% 17%
4OD to 5th 8% 11% 19%
5th to 5OD 28% 25% 17%
5OD to 6th 7% 10% 17%
6th to 6OD 28% 25% 17%
(The ZF6 does NOT split this nicely!)
The two existing overdrive boxes do give you "twice as many gears", but as you can see, the steps are so small that in most cases, you really don't gain anything by splitting anything but third, so 4-5 and 5-6 are not splittable - the very ones you NEED when towing. Looking at the steps with 0. 8555, you can see why it makes a lot of sense. A 2,500 rpm shift will drop you back to 2,140 (OK, 2,100 because you will take some time, even frantically climbing a 7% grade).
After much time, we got a design study that figured out how to cut the gears without totally re-designing the box, and they considred making us some experimental sets. Now the production order is in for prototyping, and USG will do some in-house R&D. If the design works in the real world, this could become a product before too long. Will keep you posted.
Pat
Pat
