Update On The CEL I Reported Last Week
6.7 Back Pressure on intake side
6.7L Engine Issue, Chassis Cab Only
This post pertains to the Cab and Chassis 6. 7L engine only.
Last week I posted that with 24,000 miles on the odometer I had a Check Engine Light and a P0191 code. The code indicated the ECM detected an issue with the fuel rail pressure sensor. The local dealer advised me that a note from an engineer at Cummins stated that Cummins is aware of the problem and advised that in most cases, the fuel pressure sensor is not actually bad, the computer only thinks it is. The notice advised that a software update will be issued in October to correct the problem. Later I spoke to someone at Cummins and was told my symptom was different and I had a different problem.
I decided to take the truck back to my selling dealer who is 300 miles away because that dealer has a Level IV trained and certified Cummins tech. I hooked up my fifth wheel and left early Monday to go to Gainesville (TX) and spend a day or two having the truck examined and repaired if possible.
After I arrived in Gainesville and parked my trailer I was driving slowly down a local street and was amazed to glance down at the instrument panel and see that the Check Engine Light was gone.
The CEL and code had been on for a week and 3,000 towing miles and suddenly the light cleared itself.
The dealership took my truck in the following morning and checked it out and could find no cause for the CEL. I learned that the computers on the new engines are very sophisticated and are capable of monitoring many functions. The computer uses complicated and sophisticated programming that allows it to check and recheck these functions and after a programmed number of key cycles the computer can extinguish the code if it decides the original fault is no longer present.
The mysteries of computers!!! I guess I can still say my truck is troublefree after more than 25,000 miles.
Glad to hear your problem solved itself. Maybe the truck doesn't like to have the tech probe it, so it decided to behave. ;)
Probably so. I hope it continues its good behavior. It is pretty foolish and expensive to hook up and tow my fiver 600 miles round trip just so the ECM will reset the code it has been displaying for a week and almost 3,000 miles!
That was kinda my thought when you said you had to go that far for service. On the other hand, I understand about the peace of mind that comes from having someone you trust work on your rig. Tough to find that nowadays. ;)
... ... ..... On the other hand, I understand about the peace of mind that comes from having someone you trust work on your rig. Tough to find that nowadays. ;)
You accurately described my thinking on the subject and my reason for going so far.
The dealer I use is a Five Star dealer and one that is owned by one man who genuinely cares about running a professional operation. Wasteful yes, but I consider it worth the trip to go there. I can pick up the phone tomorrow and call my salesman and tell him what I want and he will order it with no paper changing hands. I'll get a copy of the invoice via fax or e-mail. In six weeks or so the new truck arrives and they call me. I go over and inspect the truck, review the invoice, and get out my check book or credit union draft. No games, no tricks, no padded pricing, and no attempts to upsell me, just straightforward honest transactions. That is worth a lot to me.
Several of the Dodge stores in the Texas Panhandle region where I live are all owned by the same investment group. None are Five Star dealers, none spend any money on technical training for their techs. Their reputations for honesty and integrity are not exemplary.
A couple more stores in this area are just small agricultural town stores with limited resources.
I go where I'm treated well.
