Update on the Mallory Fuel pump
Fuel Pressure Readings
Head gasket leaking coolant
Been running with the mallory for the past 6000 miles and it has performed wonderfully. If you will remember, I choose not to run a regulator and spliced into the old fuel line and then ran 6an up to the fuel filter with a swept 90 to a weber carb adapter. The truck idles with 12lbs of pressure and driving down the road at 70-80mph it is at 11lbs of pressure. WOT it is at 9lbs of pressure. This is with DDIII's, 4" straight exhaust, and TTPM on the highest setting.
'99 2500 4x4 QC Std transmission, Purple (usually Mud Red), 10 Disc Changer, 285x75Rx16 BFG Mudders, Amr. Racing Baja Wheels, Gooseneck hitch, 275lb King Klaw front bumper, Towing/Camper packages. DDIII's, Exhaust, TTPM, Boost Module. Fuel Pressure, EGT adn Boost Guages. Mallory Fuel Pump. (fastest farm truck around). And can't forget the hydraulic PigSticker.
2001 Yamaha Raptor, dropped tooth on front sprocket, sand skate II tires on rear.
1965 Chevy 1/2 ton Pickup, 350-350hp/2spd powerglide, PS, PB, Disc Brakes on the front, Tilt, Fuel Cell, 3. 73 posi.
26ft Gooseneck Flatbed Trailer, 2 horse bumper pull, Round bale Trailer.
1960 Farmal 340 Diesel Tractor.
Morphious, glad to hear the Mallory is working out for you. So far, mine has been great also. If it every warms up here, I'll put my SPA FP gauge in and post the results.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Go-Rhino grill guard,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
