First, why do want to replace it? That might help direct the best answer.
Along with what was mentioned above, you can use a stock lift pump from early second gen.
Or, for more flow, stock lift pump from late second gen with a pressure regulator.
I went with a Raptor pump for mine.
Some people use a Holley Black pump as well.
All the above options range from ~ $150 - $600.
If you want to stay with a mechanical pump, choose one of the second gen pumps. Which one you choose depends on what power you're shooting for.
If you want electric, there's alot of options, some being mentioned above.
Whatever you go with, remember pressure NEEDS to be regulated to less than 15 psi or you risk blowing the front seal on the high pressure pump... 12 psi may be a safer number.
