Vaughn MacKenzie
Tonight I changed my oil for the first time. It was nice to find out I don't need the "updated" oil filter since I was able to easily remove & install a pre-2003 Stratapore from above. All I had to do was remove the inlet hose to the turbo. . . no biggie. It was nice also to find out The Incredible Hulk is no longer installing the oil filters at the factory like was the case on my 2001. It spun off easily with the band filter removal tool.
I noticed in several photos of 2003s there is the APPS (throttle position sensor unit) bolted to the front of the engine like all the 24-valve trucks, but mine does not have this. There is nothing bolted there. It appears my throttle cable routes underneat the battery on the driver's side.
Another thing I decided to do was BOMB my intake turbo silencer. Some had posted they cut several holes in the piece that looked like swiss cheese, but when I pulled mine out there was only 2 flat longitudinal pieces in an X-pattern which would not pose any airflow restriction. Evidently Dodge updated it to eliminate the intake restriction.
Well not much else to report from this camp
Vaughn
Vaughn
