Updating Smarty
daily grind....
NEED 06 manual trans vin code w/o anti-theft
Apparently I'm doing something wrong. I've tried everything, followed directions on mads site to a T, still nothing will work. I did a search and followed all the suggestions... . nothing. I can get as far as the part where it says to type in C:\D2XX Drivers and click Next, and it's no good. I've downloaded everything a couple times and unzipped..... all of it. What do I do?
You are not really typing in C:\D2XX that means the actual path on your computer... maybe C:\programs\smarty\xxx where xxx is the file name you down loaded.
Be best to browse to where you have donloaded the file.
Hello , To be able to update your smarty ecm tuner. Please follow these guidelines.
Start by right clicking on your desktop to create a new folder. Rename the new folder smarty.
You will need to download the driver to the smarty folder. Save the driver to the smarty folder http://www.madselectronics.com/downloadfiles/CDM_2.00.00.zip
You will need the smarty usb. exe This program allows you to update the smarty. Save this to the smart folder LINKS TO EXECUTABLE FILES NOT ALLOWED
The driver and the software programs need to be extracted into the smarty folder using THIS extraction tool. LINKS TO EXECUTABLE FILES NOT ALLOWED?download
Here are the directions for installing the driver http://www.madselectronics.com/downloadfiles/USBDriverinstallation.pdf
Once you have the driver installed you can use the smarty usb. exe program to update the smarty software. Click on the smarty icon. Press run. You will now see a seen button. Before you hit the send button you need to load a program into the smarty usb. exe. Click on file. Open , look in the smarty folder to find the smte file to load into your smarty.
Load the file and press run. It will take about 8 minutes to update your smarty.
Thanks
Bob
Allright, not sure how it worked, but it did. I erased everything I downloaded and re-downloaded again (4th time), unzipped everything, completely skipped the first half of the directions where you type in file paths and all that garbage. Went straight to the usb. exe program and it started updating right away... took 22 minutes to update but it's all in there and works great.
