Archived upgraded hydrallics for 2003 cummins.
Archived Front Differential Full of Metal Shavings
Archived Banks Packages
I just got my dd clutch and upgraded hydrallics from SB Clutch. Now the master cylender is totally differant. how does it mount up on the third gen. rams. need help deperetly. thanks Cliff
It should already have the modified rod in the master cylinder. Removal ofthe old one is easy. Press pin out of clutch pedal, remove sensor switch from shaft, from under hood twist master cylinder CCW 1/4 turn and pull. The new one installs just the opposite and you have to screw the reservoir to the firewall above.
-Scott
mine didn't twist out it had two bolts holding it to the fire wall the new one twist in. but the fire wall in my truck isn'tmade for tha. thanks thou. any more thoughts. Cliff
