Engine/Transmission (1998.5 - 2002) Upgrades
2nd Gen Non-Engine/Transmission Troubleshooting cruise control
Well Boy's I have read about a 1000 discussion forms on upgrades since I bought my 01, 6speed, H. O. 4x4 and now need some advise on what I presume to be the overall best and most liked upgrade to the ole Dodge.
It seems the Edge-EZ ( not sure which one?) with the 2 gages (Pyro & Manifold) mounted on the pillar is the most talked about and best liked. Late if needed, this allows me to go to the 275's injectors If I think I need a little more.
I think the injectors are really a little more than I want or need, but you know how that goes.
Hate to say it but I still have (kept) the old 92. The pump is way turned up. Dyno more than the new 03's. I think however Im am now past that stage in my life???? (now retired) Just need this new truck to pull my 27' 5th wheel
Please respond!!!!! Thanks
I would add a fuel pressure gauge to the list. I have installed the Edge EZ on a friends truck and he really likes it for towing. But in the next month or so he wants the Rv275 injectors. Also might consider a set of the larger banjo fitting.
The combo really makes it come alive. .
Rick
You will like the ez 275 combo
If you remotelly like the stock power you will love the ez and 275 injectors combo they are not agressive but make it pull real well. If you could get a ride in a truck with the same set up as you want that would help you decide if you would want to any bigger.
Good luck
Craig
Basics first so you need never worry about them later. Trans/clutch and gauges, then bomb away without worrying (too much).
Robin
WBlackburn,
I have the EZ and 275's and love them for towing my 27' 5r. However, I bought my gauges first (pyro, boost and fuel pressure) then the EZ and life was good:D Then I added the 275's and OOOPs their goes my clutch. So if you go this route plan to upgrade your clutch as well. ;) Phil
