Hey everybody. I wanted to ask a couple questions about the fuel system.
First question is: I would like to install a pusher pump so I don't have to worry as much about the lift pump issues, but I am not positive about the fuel lines. Is there a section of rubber line that you all are cutting out to install these, or is it a steel line that I will need to cut? Also, is there a return line? If so, will I be able to tell easily which is the feed and which is the return?
The second question has to do with checking fuel pressure. I have heard people mention of checking it before and after the filter. My question is, where are the schrader valves located to do the check? I located one today, but really couldn't tell if it was the one before the filter or after.
Thanks in advance for any help.
