If you have to replace the upper ball joints (actually the entire control arm) on your 2WD 3rd generation truck, check the ball joint boots on your new upper control arms for binding. I'm sure you know to have a buddy turn the steering while you check that the boots slide on the ball joint stud (rather than get twisted up).
I purchased and installed a set of upper control arms from Mevotech about two years ago. On one of the control arms, the boot would not rotate against the ball joint stud. This one boot tore within the first few miles of driving. Mevotech replaced this control arm right away. Last week I realized the other boot is torn and the ball joint is worn out.
The Mevotech part number is MK7462. If you get Moog, their part number is K7462. I assume both of these part numbers are made by one of these companies. Don't know who makes these upper control arms.
Napa has Moog control arms for $186 each. That's a good bit more than what's available online. But Napa does have a limited lifetime warranty.
Paul Lohr
Paul Lohr
