Urethane trans mounts?
Rearend Noise
part throttle power
Stab
I'm in the process of installing the NV4500 conversion and clutch from South Bend. The original rubber mounts that are now under the getrash are beyond use. Has anyone replaced these with an after market urethane mounts? What does everyone recommend??
Hey Stab!:)
Mine were shot also when my truck went in for the NVG4500HD swap. I believe the mounts were replaced w/ OEM parts when Quad 4X4 did the conversion.
Give Dan a call @ Quad 4x4 (406)446-2427 and ask his advice on aftermarket mounts.
You'll love the NVG... Which SBC clutch package did you purchase?
KEENO:D
I went with the MU 0090 Con. O. Sure looks a lot better than stock! I will have an update as soon as it is installed.
