I just pulled the driver front wheel off my '99 2500 to check out the brakes cause something didnt feel right on the way home. My outer pad is just starting to munch into the outer lip of my rotor. Basically, no more pad left and the anti-squeel tab didnt make a sound yet. One rivet is making contact with metal. I just caught it. The inner pad has more than 1/4" of meat left?? Pulled the passenger side off and the same thing except the outer pad isnt as trashed and has some life left. Is this uneven wear normal from inside to outside? If it is a bad caliper, it should be covered under warranty, right?? One last question... . would it be ok to just replace the pads even though I have a slight groove on the outside edge of the rotor? I hate the thought of cutting them. Thanks in advance to all who take the time to reply!!!!
