Engine/Transmission (1994 - 1998) US GEAR EHX.BRAKE-will it work?
2nd Gen Non-Engine/Transmission Drive shaft removal
I was wondring about the using a inline US Gear ehx. brake like a pac-brake operates , being able to have the brake on all the time. Seem like that you could access the #-20 pin on the ECM and use a solinoid , like is on the pac-brake, and use a relay to power the electric sol. on the US Gear brake. anyone have an opinion or know if this will work TIA:cool:
That should work fine.....
However, you definetely need a relay to power it. I am assuming here that you are going with an electric version of the US Gear brake!!!
