The US Gear auxiliary transmission can be purchased as either an overdrive OR underdrive unit. The Gear Vendors is an overdrive unit ONLY. It can only underdrive by overdriving the next lower gear in your main transmission.
You will have to lengthen the front driveshaft and shorten the rear driveshaft (on a 4x4) with the US Gear unit. And there is the question of the transfer case shift linkage... I'm not sure if lengthened linkage accompanies the installation kit or if they expect you to cut another hole 11" back from the present hole. Does anyone with the US Gear unit installed in a 4x4 have the answer to this?
'98. 5 2500 QC 4x4, (black) SLT Sport, ISB, LWB, 3. 54 LSD, auto. , 275 hp. injectors, Glasstite Vision II "canopy", 285 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, VDO Vision gauges, BD exhaust brake and TorqLoc.
