I have read several threads on how to change the springs out while leaving the head attached to the engine and they don"t mention the use of air to keep the valves up. Just put the piston at tdc. But I have asked several gaser mechanics and they say I will have to use air to hold them in place?? If you have done this job can you chime in and let me know if it is needed and if so, how?. Will I need to pull out a fuel injector or do I put air in some other way. I got the pac-brake kit to install after the 60# valves spring get changed out. If their are some good threads/forums to follow please point me in the right direction. Thanks TDR's.
