I found a pristine 1 owner trade in at the local Dodge dealership. 4x4 2500 Quad Cab long bed SLT Laramie Plus. Charcoal Metallic, all OEM. Used to tow a camper on trips a few times a year.
When the previous owner (whom I called and lives nearby) was in Ohio on a trip... he noticed he was low on power that he was typically used to. So he drove it home lightly and didn't worry too much. The dealership (this one) replaced the VP44... and installed the in-tank retrofit kit. This was last summer. Its had about 3K miles on it since. He got a new MegaCab which is why it was traded it. He's about to retire and wants to pay off a new one.
So what are my options if I buy this for $17,000. Will I be under the gun to do something besides the in-tank deal to prevent meltdown of a brand new VP? Or will I be OK as is? Seems like some think the retro is fine... . while twice as many more say 8psi-"high volume" is not good.
Truth be told... I'd rather just have a new Carter and a gauge. At least with the carter replacement is a snap. Even if its all to often.
I've read Glacier Diesels writeup on the new system. Since they describe the setup as "robust" but flawed... wondering if this could be pulled and modified. As in do away with the flapper valve inlets, venturi deal, bypass etc. Or at least make it so fuel can get to the pump easy and "limit" the internal 8psi internal bypass. OR something.
Leave it up to Chrysler to develop a fix that is twice as bad as the original problem.
AirDog seems OK I guess. Glacier walbro kits seem OK. I just didn't want to do another fuel system re-do as I once did on the 99. Bad memories and lots of time and cash outlay.
Wouldn't mind the Raptor stand alone pump and gut the in-tank setup to use a simple standpipe... keep the fuel level equip only.
