used turbos
Steering Stabilizer/tach Search
TDC Pin Part# or Dimensions
I'm posting this for a friend.
He has a 91 350 and is looking for a good used turbo to replace his.
Anybody know where he can get one?
TIA
Nathan
Better find out if his 350 is intercooled.
There is a difference in the intake side plumbing. The intercooled turbo intake has a V clamp bump on it. The non intercooled one only has a bump for a hose clamp. You could use a intercooled intake on a non itercooled turbo. But you loose at least 6psi of boost going this way.
You can not use a non intercooled intake housing on a intercooled turbo. The housing will not bolt down. The intake side impellors are different between the two turbo's.
old but good
Nathan,
I still have the one off my 93 (intercooled). I swapped it out up at PDR. It's just sitting in a box. Drop me a PM if that'll work.
- Sam
Used turbo
I will have a complete turbo this spring setting around taking up space. Off my truck. Anyone interested please pm as it will no longer be of use to me.
Greenleaf
